-   -   Water Storage (http://www.diychatroom.com/f7/water-storage-130762/)
jburd964 01-20-2012 05:38 PM
Water Storage
Thinking of adding a water storage tank in my attic while being on a city water system for emergency use. Anyone have any suggestions on how it could be set up?
titanoman 01-20-2012 05:45 PM
How many gallons at 8lbs to the gallon?
TarheelTerp 01-20-2012 06:33 PM
on a floor designed to support fiberglass batts and xmas ornaments?
Bondo 01-20-2012 07:03 PM
Ayuh,... 'n how big is yer attic access,..??
jburd964 01-20-2012 07:45 PM
I'm going to mount over closet after installing additional cross section of deck support. Volume to be determined by biggest tank fitting into 24"x 48" drop stair opening and weight that could be supported.
I'm not a professional., But I did stay at Holiday Inn Express last night.
titanoman 01-20-2012 07:51 PM
So no more than 2' around over a closet. You'll be alright as long as the closet don't fall over.
Make sure the container is sealed or it will be putting a lot of moisture into the attic.
TarheelTerp 01-20-2012 07:54 PM
1 Attachment(s)
I bet you can stuff a pretty big one of these through that opening:
Bladder Water Tanks are designed to provide you with a flexible tank that can safely store your drinking water. Made from NSF 61 and FDA compliant materials, these tanks have stored drinking water for FEMA operations, rural construction sites, residential water storage and more. Sizes range from 2.5 to 210,000 gallons source
jburd964 01-20-2012 10:48 PM
Thinking of using regular water well tank. Running all house water supply through tank, with check valve to prevent back flow.
gma2rjc 01-20-2012 11:41 PM
Here's another way to store some water if you know of an emergency in advance.
http://www.waterbob.com/Welcome.do;j...D5D0354DE4641C
AllanJ 01-21-2012 09:17 AM
You do not want a tank with the water surface open to the atmosphere that draws in (non-sterile) air when you use water (and the air escapes when the tank refills).
So nowadays bladder tanks are the best choice. The tank should be positioned with the air valve upwards and the air valve should be left open. Optionally pressurize the tank while it is empty to about 3 PSI and close the air valve.
The higher you prepressurize the tank to, the less water will enter the tank before system pressure (water main pressure or well pump pressure) is reached and the inflow stops. Meanwhile if you let the tank fill up and then close the air valve, a partial vacuum will develop in the tank in time of need and gravity will not be enough to get water out.
