Water Stops For 20-30s Sometimes - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-24-2009, 12:45 PM   #1
hohadcr's Avatar
Rewards Points: 316
water stops for 20-30s sometimes
On the 3rd floor of the building, the water sometimes stops totally for 20-30s, and then comes back to normal. What may cause this?
The water supply system was redone in around 4-7 years ago and using pex flexible piping.
Thanks.
hohadcr is offline   Reply With Quote
Old 08-24-2009, 06:23 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Improper sizing..
Turn on a faucet on the top floor and then go to the main floor and start turning on faucets or the washer or the dish washer and see if the flow drops out.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
rattling pipes when water heat exchanger stops Amilcar HVAC 2 04-06-2009 02:44 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Water Stinks with recirculation pump carike Plumbing 6 08-05-2008 08:01 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
