Water Stopped Coming To My Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-21-2009, 07:34 AM   #1
Water Stopped Coming to My Toilet
I sometimes turn off the water valve on my toilet upstairs, as it will keep filling up the bowl during the night. (thats a seperate problem I need to fix).
Anyway, when I got up this morning, I flushed it and noticed it didn't fill back up. I figured the water valve was closed, so I went to open it, but it was already open. I tried closing it and then reopening it, but nothing...it didn't make a sound. There was no water coming in to my toilet.
What could be causing this? I'm in Houston, and we didn't have any freezing weather last night.
The house was built in 1991.
limitdiy is offline   Reply With Quote
Old 12-21-2009, 08:15 AM   #2
Rewards Points: 150
probably some type of sediment is plugging your ballcock assy.in the toilet.probably caused by turning the supply stop on and off.make sure the water is off to toilet and clean the fill valve.
rudolph58 is offline   Reply With Quote
Old 10-18-2011, 07:30 PM   #3
Same issue, welcome to the club, no water to toilet
I have the same problem, I removed my hose that connects the valve to toilet, still no water. The sink and tub seems to be fine, don't seem to have lost any water pressure, so I dont think its a leak. Need the same help, was getting a lil noise in the pipes, also.
danknee is offline   Reply With Quote
Old 10-18-2011, 07:36 PM   #4
AlbacoreShuffle's Avatar
Turn the water off to the toilet
Disconnect the water supply to the toilet.
Get a bucket and hold the supply line in the bucket.
Turn the water back on, if you have pressure, replace the fill valve.
If you don't have pressure replace the shut off valve.
If that doesn't work , you have a nice little project on your hands.
AlbacoreShuffle is offline   Reply With Quote
Water coming in under bathtub thesinks Plumbing 1 07-04-2009 08:14 PM
water coming up water supply liner candaneh Plumbing 3 03-30-2009 09:50 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Help! The water is pouring into my tub and toilet! gingerspace Plumbing 16 12-14-2008 01:38 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
