Water Stain On Ceiling - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-20-2009, 09:14 PM   #1
Water stain on ceiling
I just noticed a small stain (light brown about the size of a lemon) on my dining room ceiling. The master bathroom is located on the 2nd floor in the same area. I don't see any leaks in the toilet or around tub. What could be causing this and what is involved in repair? Plumber? Drywall? Help!!! Thanks!
jend300 is offline   Reply With Quote
Old 09-20-2009, 09:35 PM   #2
It could be as simple as someone got water on the floor and it soaked down or a leak through the tile and a leaking pipe. You will need to open the ceiling and get it to leak in order to tell.
plumber Jim is offline   Reply With Quote
Old 09-20-2009, 10:27 PM   #3
Could be a bad wax seal on the toilet.
hayewe farm is offline   Reply With Quote
Old 09-21-2009, 08:09 AM   #4
Thanks for the info. Either way it sounds like I'm going to have to call a plumber.
Jend is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Ceiling water damage below flat roof with EPDM gofurther Roofing/Siding 11 03-23-2009 12:27 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
