Water Squirting Out From Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree8Likes
  • 3 Post By joecaption
  • 1 Post By SHR Plumber
  • 1 Post By RRH
  • 2 Post By Ghostmaker
  • 1 Post By puttster
Old 01-08-2017, 08:33 AM   #1
Rewards Points: 322
Water squirting out from pipe
Dropped to 20 deg last night in Houston. This morning there was water squirting out from under a round cap on an outside pipe (pic). The cap lifts right off but I couldnt figure out how to stop the water so I turned it off.
What's broken and how do I fix it?
puttster is offline   Reply With Quote
Old 01-08-2017, 09:23 AM   #2
joed's Avatar
Rewards Points: 13,354
Re: Water squirting out from pipe
That's a vacuum breaker for what looks like the feed to the sprinkler system. If it froze it probably broke and needs to be replaced.
Old 01-08-2017, 09:35 AM   #3
Rewards Points: 14,026
Always blows me away when I see plumbing like that ran outside like that, only a matter of time before it freezes.
Bondo, BlackTiger and supers05 like this.
Old 01-08-2017, 11:39 AM   #4
Rewards Points: 322
Is there a way to see if it is fatally damaged?
Old 01-08-2017, 02:36 PM   #5
Rewards Points: 322
Probably it is fatally damaged. Under the cap is a diaphragm, when I push down on it, I see that only one side is still attached.
Is the replacement a challenge? I see where the threads are ... just one wrench? Unscrew the nuts on the other side of the teflon tape and lift out the unit?
Or am I better off getting a repair kit like https://www.amazon.com/Blue-Heron-Re...ds=febco+765-1
Old 01-08-2017, 03:49 PM   #6
joed's Avatar
If you get real lucky you might fix it with a repair kit. Depending on what is broken you might be just buy a new one exactly the same and pull some guts out and put in the old one. Untill you open it up and look inside you won't know what is broke.
One wrench will not do it. You will need two, one on each side of the fitting you are unscrewing.
Old 01-08-2017, 07:36 PM   #7
Rewards Points: 30
If that valve broke, the system was not properly winterized. The valve is toast. Replace with entire new valve. Remember the $100 cost of the new part next fall and blow out your system.
BlackTiger likes this.
SHR Plumber is offline   Reply With Quote
Old 01-08-2017, 09:49 PM   #8
Rewards Points: 2,040
Just repair it.
Old 01-08-2017, 11:30 PM   #9
RRH
Rewards Points: 322
Just consider yourself lucky if that is the only problem.
You may still have broken lines in the rest of the system. You will not know until you run each zone next time.
You need to have the system blown out before any freezing temps. Or it could get real expensive replacing lines.
Worth the investment to buy your own compressor and do it each winter. Instead of what most do and pay a sprinklers company to winterize the system.
RRH is offline   Reply With Quote
Old 01-09-2017, 04:45 PM   #10
I don't think he expected freezing temperatures in Houston Texas.
SHR Plumber and Brad_TX like this.
Old 01-09-2017, 09:48 PM   #11
Usually Confused
lenaitch's Avatar
Rewards Points: 1,992
I'm noticing quite a number of posts regarding plumbing, heating, condensation, etc. from areas that probably don't normally see cold weather and aren't geared for it.
Possibly a brave new world.
lenaitch is offline   Reply With Quote
Old 01-10-2017, 04:49 PM   #12
Then evil Russian scientist predicted this 2 years ago. Yes we are going to experience colder temps.
Old 01-16-2017, 10:54 AM   #13
Rewards Points: 322
Thanks to advice given here I purchased a Blue Heron repair kit for $23, watched a youtube video and installed it. in 5 minutes The design of the new one is somewhat different than what was installed but the sprinklers are working fine now.
jmon likes this.
The Following User Says Thank You to puttster For This Useful Post:
SeniorSitizen (01-16-2017)
Old 01-16-2017, 05:44 PM   #14
jlhaslip's Avatar
Rewards Points: 2,820
Originally Posted by puttster View Post
... but the sprinklers are working fine now.
Just in time to winterise the system before it freezes again.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 01-19-2017, 10:50 AM   #15
Rewards Points: 22
That's awesome that you fixed it for less than $25! This weather in central/south Texas has been crazy.. It didn't even freeze last year and my pepper plants survived the winter. Not this year though.
Brad_TX is offline   Reply With Quote
How to apply caulk to seal water pipe through basement wall goshenplumber General DIY Discussions 4 07-08-2013 08:40 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
loud jackhammer-like noise from hot water pipe omar Plumbing 15 01-08-2012 01:53 PM
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 05:42 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
