Water Source From Fridge From Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-06-2008, 10:20 PM   #1
Water source from fridge from water heater?
Question,
I need to supply the fridge I just bought with water for the ice maker. There is currently no source where the fridge will be. The sink is on the other side of the kitchen but there is a water heater on the other side of the wall. Would it be a good idea to get the water from the cold water source for the water heater and run it through the wall? Or should I look for another way?
-Dank
dankreboot is offline   Reply With Quote
Old 07-07-2008, 10:54 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
There is no reason why you can't tap the nearest cold water supply line, no matter what it's supplying.
If this is over a basement or crawlspace, it probably would be easier and look better to tap the line under the floor than go through a wall.
Just install a T in the line plumbed through the floor/wall with a shut-off valve on it behind the refrig with an adapter to connect to the 1/4" refrig water supply line.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-08-2008, 10:16 AM   #3
RippySkippy's Avatar
To elaborate a bit on what Mike said, it's best if you can install a T with a shut off (if your going into a wall behind the fridge, don't bury a shutoff in an area that could eventually be finished, just "T" up to an outlet box with a valve. If that's not an option use a saddle valve, again though, don't put it in a place that could be buried like above a finished basement ceiling later.
Sidebar: My previous neighbor had that happen to him...bought the house with the appliances, fridge w/ice maker. Fridge died, and the plastic supply tube went through the kitchen floor into the basement ceiling, and was old and brittle. When the fridge was remove the tube cracked, and the only way to shut it off was to first turn off the whole house water supply. Later we decided to see if we could locate the supply shut off to replace the plastic tube with copper. We did...but had to poke a couple of holes in his basement ceiling to get to it. Of course we removed the valve and relocated the supply tube to a more convenient location.
I personally have not had the best luck with the saddle valves. I would recommend using copper supply tubing rather than the vinyl/plastic. I've had way better luck with copper as it does not get brittle over time, one leak is too many when it's behind/under the fridge.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 07-11-2008, 02:10 AM   #4
I've tapped the cold water going to water heater
I've used a T plus some reducers and some tubing, but it seems to be release a tiny bit of water (enough to form a drip after about 10 minutes) at the T , everything is brand new, and I've used the thread tape, is there too much pressure? Is there something I can possibly do to prevent any type of water being released?
Old 07-11-2008, 02:18 AM   #5
Long-Time DIYer
What type of pipe and what type of T? Is it a threaded fitting or a compression fitting?
If it's threaded, you can add pipe compound to the teflon tape on the threads and tighten the fitting more.
If it's a compression fitting, the brass ferrule rings seal it, not the theads. Smear pipe compound or clear silicone on the ferrules. You do not need to put anything on compression fitting threads themselves.
Good Luck!
Mike
Old 07-11-2008, 06:30 AM   #6
Send a message via AIM to Marlin
Take a picture if you can.
Use a copper tee that is 3/4", 1", or 1/2" (depending on the size you're tapping into) by 1/2" sweat. Use a short piece of half inch pipe and a 1/2" sweat by 1/4" compression speedy valve.
Marlin is offline   Reply With Quote
Old 07-11-2008, 10:03 AM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
We don't use them either, i'm not sure if they're illegal or if my boss just doesn't like them, but they create turbulence, which wears out the pipe more rapidly as we all know.
Journeyman Plumber
Old 07-11-2008, 04:40 PM   #8
They are illegal almost everywhere and I would highly recommend against them.
Old 07-11-2008, 05:34 PM   #9
turbulence
Can you post links that talk about turbulence, pipe lifetime, laminar flow and vibrating faucet washers?
This turbulence/pipe-lifetime relationship is news to me.
Thanks (not an Mech. Eng.).
Old 07-11-2008, 09:21 PM   #10
Doing it myself
Alan's Avatar
I don't know about any source info, but thats why plumbers always ream/deburr their copper pipes when they solder, and why hot water lines in a recirc system fail sooner than the cold side.
Journeyman Plumber
Old 07-11-2008, 10:19 PM   #11
recirc system
Good keywords!
http://www.ccbda.org/publications/is...ication-e.html
Old 07-12-2008, 11:08 PM   #12
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
Dankreboot,
I'm not clear on where you are having the leak but here is the simplest set up:
Cut a tee into the cold water line that feeds the water heater, since you indicated that was the closest source of cold water.
This is usually a 3/4" line, so use a 3/4" x 3/4" x 1/2" Tee. (This has the 1/2" out the side.)
Either install an icemaker box in the wall behind the fridge (recommended) or just stub the 1/2" pipe through the wall and install a 1/2" x 1/4"OD stop.
Use one of the new prefab type connectors, either braided or the hose type, to connect to the fridge. These eliminate the problems with both copper and plastic lines.
Whatever configuration you decide on, there should be no leak, no matter how small.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
