Water Softner Resin In The Tap Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-24-2012, 05:51 AM   #1
Rewards Points: 22
Water softner resin in the tap water
I found tiny golden pellets in our bath water and clogging an aerator suddenly today. I eventually figured out they were bits of resin from the water softener and shut it off with the bypass valve.
The softener is a Fleck 5600 that came with the house making it more than 10 years old. I replaced the control head myself 4 years ago so really only the resin tank and everything in it are old.
Can you give me some idea what part needs to be replaced before I start taking it apart?
Thanks! - Tom
retrofitz is offline   Reply With Quote
Old 11-24-2012, 08:10 AM   #2
Rewards Points: 3,130
May I suggest you'd be better off replacing the softener with a new one. I've never had one that even lasted ten years.
Old 11-24-2012, 12:31 PM   #3
Water Treatment
Rewards Points: 848
When you replaced the control head, did the distributor come up any?
It is possible that the bottom of the distributor cracked when putting the control back and pushing down on the distributor and it has finally given way.
There are systems that can last well past the 10 year mark. Not sure of the systems that you have been dealing with or the water quality.
Akpsdvan is offline   Reply With Quote
Old 11-24-2012, 10:45 PM   #4
Rewards Points: 22
I'd much rather not replace the whole thing, especially since the controller is only 4 years old and should have some life left in it.
I don't remember much about putting it back together, but I did have the same thought that maybe I applied some downward pressure on the tube. I'll start by checking the bottom distributor, and now that I know what its called, should be able to order a new one if it's damaged.
I'm debating whether to change the resin while I'm in there, depending on how it looks and how much is missing.
Thanks!
Old 11-24-2012, 11:04 PM   #5
Water Treatment
Rewards Points: 848
Depending on the age of the system and the water quality as to time for replacing the resin.. yours might have gravel at the bottom..
Should you order a new distributor you will need to know the size of the tank in height..
To many today are use it and then put in the dump, I would rather replace parts if they can be had and keep a system going till the time is truly there that says it is time to replace.
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
