Water Softner Question... - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-29-2012, 06:00 PM   #1
When I moved the water softner I hooked up the conenctions backwards.
It was about 2 weeks before I realized that the sand in the system was coming from that and not some rural water issue.
Do I need to replace the softner or will everything work out OK?
What should I be looking for?
I have already cleaned out aerators, valves and the assorted toilet items of the sandy like substance.
Thanks in advance.
Lefte
Lefte is offline   Reply With Quote
Old 10-29-2012, 06:09 PM   #2
Water Treatment
Rewards Points: 850
Have you changed the in and out fittings to the correct in and out?
Depending on the make and model of the system in question as to will the system return to normal operation or some thing else will be needed to make things right.
Akpsdvan is offline   Reply With Quote
Old 10-30-2012, 05:31 PM   #3
Yes it has been set up correctly at this point.
Lefte
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 05:10 PM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 01:59 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
Yet another sump pump / pit question SeanFlynn Plumbing 0 01-24-2010 02:07 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
