Water Softner Media Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-23-2013, 08:03 AM   #1
Rewards Points: 284
I have a two tank system. One for hard water and one for iron. At what age is water softener and iron media replaced?
Thanks.
Earnie is offline   Reply With Quote
Old 10-23-2013, 10:38 AM   #2
Water Treatment
Rewards Points: 902
It is more along the lines of usage and quality of water.
What is the level of iron in the water?
What is the level of hardness in the water?
What else is in the water that the systems are taking out?
How many people are in the house?
How often are the systems cleaning or regen?
Ever go with out the regen for either ..?
Akpsdvan is offline   Reply With Quote
Old 10-23-2013, 10:38 AM   #3
Master Plumber
Benplumbing's Avatar
It really depends on the quality of the water entering the filtration systems. Are you experiencing lower than usual water pressure?? How old are the units?
Benplumbing is offline   Reply With Quote
Old 10-23-2013, 11:14 PM   #4
Rewards Points: 208
if it's well water laced with tiny black flecks entering your water softener, then wouldn't the softener flush out the minerals and flecks during regeneration?
Scully is offline   Reply With Quote
Old 10-24-2013, 07:23 AM   #5
Rewards Points: 284
What is the level of iron in the water? Before treatment 0.50 mg/l
What is the level of hardness in the water? Before treatment 78 mg/l
What else is in the water that the systems are taking out? County tested for many inorganic chemicals. Only items over the recommended limits was iron and manganese.
How many people are in the house? 2 adults.
How often are the systems cleaning or regen? Once per week.
Ever go with out the regen for either ..? Not that I know of.
Systems was installed in 2009. Has two tall tanks with Autotrol 255 Valve / 400 Series Controls. I'm just asking if the media lasts forever as long as it goes through regeneration or if at some point it's replaced.
Old 10-28-2013, 06:12 AM   #6
Rewards Points: 284
So, does the media get replaced after years of use or not? Does it last forever?
Old 10-28-2013, 07:28 AM   #7
Rewards Points: 44
It won't last forever but it will last a very long time. My softener is 11 years old and still works great. The softener resin bed can get clogged with iron but there are chemicals and salt additives that will clean it out. I can't speak to your iron system.
I have a pre-filter on my system to keep junk from reaching the softener. I'm on city water and it still catches a good amount of junk. Might be worth looking into.
Dan
djlandkpl is online now   Reply With Quote
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
