Water Softner Draining - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-21-2008, 01:50 AM   #1
Water softner draining
Hello, I was wondering if it is ok to run the water softners drain tubing and overflow tubing to a sump crock? It is for ground water and eventually goes to a retention pond.
Thank you,
Norm
Mr. Baughman is offline   Reply With Quote
Old 03-21-2008, 09:52 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 628
Ayuh,... Sure,.. Why Not,..??
Old 03-22-2008, 12:26 AM   #3
The directions say to a stand pipe, slop sink, or floor drain. These are all on the sanitary waste lateral. I don't know if it is legal and could if the brine would harm the retention pond. I know it's not much, but if everyone in the neighborhood did it, i imagine it would cause a problem.
Water Softner Overhead drain MIWW Plumbing 1 02-27-2008 10:07 PM
Rain water draining into sump pit ERIK2173 Building & Construction 19 07-20-2007 10:19 PM
water softner repair ranchody General DIY Discussions 3 05-28-2007 01:41 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
