Water Softner - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-14-2012, 04:43 AM   #1
water softner
Does water flow out into a drain when it goes through its recycle process?
suesteward is offline   Reply With Quote
Old 03-14-2012, 05:51 AM   #2
DIY staff
Rewards Points: 7,174
Yep--15 to 20 gallons will go down the drain---or onto the flood if the drain is plugged up--Mike---
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 08:35 AM
No hot water past the valve at top of hot water heater-?- Daulton Plumbing 4 04-03-2011 02:47 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
