Water Softener Whistles - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-24-2011, 04:35 PM   #1
Water Softener whistles
My water softener whistles only when running hot water, not cold. What is causing this? It is a Kenmore Model 625.348591.
MikeLV2010 is offline   Reply With Quote
Old 12-24-2011, 05:10 PM   #2
Lightfoot's Avatar
Rewards Points: 272
are ya sure it's the machine itself?
could it be a nearby supply line with a joint somewhere close?
Lightfoot is offline   Reply With Quote
Old 12-24-2011, 05:11 PM   #3
Perhaps only the hot water is softened so water is only running through the softener when the hot water is used. Check your plumbing setup to see.
But even if that is the explanation the softener shouldn't make a whistling sound--I suspect some type of partial blockage in the valve.
Bob999 is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
What to put under water softener? wiz561 Plumbing 4 12-11-2010 09:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Went to city water - softener still needed? uncleslam General DIY Discussions 5 11-15-2009 05:08 PM
