Water Softener Started Regenerating When I Was Changing The Water Filter - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-07-2010, 06:17 PM   #1
Question
Water Softener started regenerating when I was changing the water filter
Hi guys,
I was in the process of changing the whole-house water filter (with water flow turned off) when suddenly the water softener started its regeneration cycle.
I knew that wasn't good so I quickly finished the filter change and turned the water back on. When I turned it back on, I could tell there was a significant amount of air in the line for the water softener (making all sorts of 'sucking' noise).
My question is this: do I need to bleed the air out of the line, or will it eventually pass the air completely through the water softener?
Thanks!
nicksergeant is offline   Reply With Quote
Tags
air , plumbing , water , water softeners
Changing filter in Whirlpool whole house water filter farnamct Plumbing 7 12-20-2012 09:11 PM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
Water softener no longer softening water grandmajo Plumbing 3 01-19-2009 06:42 AM
Is this a viable solution for a water softener? imola ghost Plumbing 1 12-23-2008 10:51 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
