-   -   Water Softener started regenerating when I was changing the water filter (http://www.diychatroom.com/f7/water-softener-started-regenerating-when-i-changing-water-filter-86072/)
nicksergeant 11-07-2010 06:17 PM
Hi guys,
I was in the process of changing the whole-house water filter (with water flow turned off) when suddenly the water softener started its regeneration cycle.
I knew that wasn't good so I quickly finished the filter change and turned the water back on. When I turned it back on, I could tell there was a significant amount of air in the line for the water softener (making all sorts of 'sucking' noise).
My question is this: do I need to bleed the air out of the line, or will it eventually pass the air completely through the water softener?
Thanks!
