Water Softener Salt Not Dissolving - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2012, 03:50 PM   #1
Water softener salt not dissolving
I have a Master Water conditioner. We used to add salt everyother week, but now the same salt stays at the same level and doesn't dissolve. I cleaned out the small filter, but nothing. Any ideas?
dpiranio is offline   Reply With Quote
Old 02-19-2012, 04:08 PM   #2
Rewards Points: 13,300
Is the timer changing position?
Old 02-19-2012, 04:10 PM   #3
Water Treatment
Rewards Points: 850
Is it that the system is not removing the water from the salt tank?
How often does the system clean or regen? days or gallons?
I have filled a salt tank with salt when there is no salt but water and the salt did not drop down because the water already had the 26% salt load and would not dissolve any of the new salt put in the salt tank.
Akpsdvan is offline   Reply With Quote
Old 02-19-2012, 04:19 PM   #4
Lightfoot's Avatar
Rewards Points: 272
I'm not entirely familiar with that brand and the salt storage, but could the salt be "bridging" ?
Lightfoot is offline   Reply With Quote
Old 02-19-2012, 04:31 PM   #5
Rewards Points: 636
i do not know much about water softners but i love to learn
so is bridging where salt holds together and to sides so only salt below desolves only
and has water consumption changed i have fixed a running toilet for someone and that was why it was using high amounts of salt
jaydevries is offline   Reply With Quote
Old 02-19-2012, 04:35 PM   #6
http://www.allwaterpurification.com/...eshooting.html
This may give you some ideas.
Old 02-19-2012, 05:51 PM   #7
Lightfoot's Avatar
Rewards Points: 272
Yep, i had one at a car wash, that the salt under the top was completely gone, but the bridge covered it. I took a broom handle, poked thru it and there was nothing underneath but water. Wasn't even touching the salt left at the top.
Old 02-21-2012, 07:11 AM   #8
Lightfoot's Avatar
Rewards Points: 272
must've fell in the salt barrel head first.
Low water Pressure with water softener garden Plumbing 8 07-31-2012 02:03 AM
getting metals out of well water without a water softener? mlc28 Plumbing 6 11-19-2010 11:28 PM
Water Softener shooting water. morgan7c Plumbing 5 01-31-2010 10:23 PM
Soft water softener leaking salt taste into plumbing??? BobnSofi Plumbing 2 06-01-2009 12:27 PM
Water softener salt hog sk8z Appliances 5 10-10-2008 07:49 AM
