Water Softener "Rotten Egg" Smell - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-22-2011, 07:18 PM   #1
I just installed a culligan water softener and now I have a rotten egg smell after I'm done showering. Can someone tell me whats the best way to clean it. Should I use Bleach on the salt or something else. TIA
WGFA is offline   Reply With Quote
Old 09-22-2011, 07:53 PM   #2
Is the egg smell only in the hot water? If so it is probably a problem with the anode in your hot water heater. Changing the anode rod will typically resolve the problem but there are also other approaches.
This link may help you:
http://www.waterheaterrescue.com/pag...r-heaters.html
Bob999 is offline   Reply With Quote
Old 09-22-2011, 07:59 PM   #3
Well not sure but I just installed the water softener and it started that night...
Old 09-23-2011, 12:05 AM   #4
Rewards Points: 156
Do you have well water? I've heard that sometimes high levels of iron can leave a smell like that.
strategery is offline   Reply With Quote
Old 09-23-2011, 01:02 AM   #5
no I have city water...
Old 09-23-2011, 09:12 AM   #6
Run the cold water only in the shower to see if you get the smell. If you don't then run the hot water only in the shower to confirm the hot water is the source.
If the hot water is the source see my first post.
Culligan water softener not working (pics) Perm Plumbing 46 09-14-2011 01:29 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
Water heater/Water softener issues norrisboat Plumbing 2 01-24-2010 02:17 PM
Water softener no longer softening water grandmajo Plumbing 3 01-19-2009 07:42 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
