Water Softener Resin - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2010, 08:13 AM   #1
Rewards Points: 163
Does the resin in a water softener ever good bad or wear out? If it's cleaned regularly will it last forever? My softener is 17.5 years old so I am think it is over due for replacement but wanted to get some opinions about the resin bed.
kb3ca is offline   Reply With Quote
Old 10-14-2010, 10:34 AM   #2
lloydb's Avatar
Yes it does wear out. The beads eventually get mushy and don't exchange properly.
I used to work for Rainsoft and I think I may some new resin I'd make you a deal on if you're interested.
I'd have to look to be sure though.
Broken Arrow hvac Broken Arrow Air Conditioning
lloydb is offline   Reply With Quote
Old 10-19-2010, 12:20 PM   #3
Still going...
ChrisDIY's Avatar
Rewards Points: 508
How long does it take to get mushy? I'd be curious to see what's more cost effective? Taking unit apart "properly" getting resin in vs. buying a new one...?
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 10-19-2010, 02:08 PM   #4
lloydb's Avatar
If memory serves me correctly, the higher the chlorine content, the faster the beads break down. I would expect the resin to last well past ten years in most instances.
But you raise a good point. It may make more sense to get another softener if it's nearly 20 years old.
Old 10-19-2010, 02:51 PM   #5
Rewards Points: 150
I replaced the resin in my softener due to a rust bacteria clogging up the system, it was very reasonable and pretty easy to do. I want to say I spent maybe $100? I have fleck valves in mine, so rebuilding is cake. We have a local company that assembles and services water softeners, they sold me the media and gave me some pointers.
Evan
240sx4u is offline   Reply With Quote
Old 10-20-2010, 01:56 PM   #6
Rewards Points: 163
Well, I took a water sample to Sears for a test after cleaning the resin and regenerating the softener a couple of times. The water was absolutely soft! I think I should have programmed it to recharge more frequently as it got older. Seems to be working just fine now but I am still going to look into replacing it due to age. I've had it since January 1993 and it doesn't owe me anything.
GE 40,000 Grain Water Softener soxcycling Plumbing 7 04-08-2010 05:20 AM
Went to city water - softener still needed? uncleslam General DIY Discussions 5 11-15-2009 04:08 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
Help with Water Softener TTran Plumbing 5 05-27-2009 06:08 PM
Water Softener wont stop draining help TTran Plumbing 3 08-24-2008 08:16 PM
