Water Softener, Replace, Or Replace Beads? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-03-2014, 10:58 AM   #16
Rewards Points: 175
If there are no salt free solutions, I think I might go with a fleck 7000. Anyone have advice on a good place to buy online?
Like this:
http://www.qualitywaterforless.com/F...-r48-70sxt.htm
What resin media should I get? Res care feeder useful? Anything else I should get for a replacement project?
vivithemage is offline   Reply With Quote
Old 02-06-2014, 02:48 PM   #17
Rewards Points: 175
So I sent these same questions out to a vendor, and they came back with:
Get the 5600 .The 5600’s have a 40 year track record. The 7000’s have been a problem from day 1. They changed the bypass assembly and it is terrible. I have had more problems with a Fleck 7000 than I care to remember.
Any truth to that? is the 7000 that much worse then the 5600 from ya'lls perspective?
Old 02-06-2014, 05:46 PM   #18
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Like this:
Im a fan of whole house water filters myself , id try that first then see how water looks before installing a softener.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-06-2014, 10:11 PM   #19
Rewards Points: 175
What do those get out exactly?
Also, we have pretty hard water...
br, 2ba, municipal water with 32 grain per gallon. A little bit of iron, unsure of actual rating, but it exists.
Old 02-06-2014, 10:14 PM   #20
plummen's Avatar
Depends on which cartridge you use and what kind of issues your water has.
Old 02-06-2014, 10:21 PM   #21
Rewards Points: 175
The water is hard and has a bit of iron in it ... no other issues from the municipal! I also want to keep up the water pressure, my old water softener kills it.
Old 02-06-2014, 10:27 PM   #22
plummen's Avatar
You can take a lot of the iron and rust taste out with a filter.
Old 02-06-2014, 10:39 PM   #23
Rewards Points: 175
It isn't the iron I am worried about, it's the hardness...leaving everything chalky and clogged up at the faucet/appliances/etc...iron is very minimal and tolerable.
Old 02-06-2014, 10:51 PM   #24
plummen's Avatar
You might be suprised at how much better the water will taste/feel with a filter installed.
If you end up adding a softener later it shouldnt have to work as hard if you take some of the other stuff out before it gets there
Old 02-07-2014, 09:29 AM   #25
Rewards Points: 175
What can a whole home filter do for hardness levels?
Old 02-07-2014, 09:51 AM   #26
plummen's Avatar
All I can say is try it and see if it improves your water, you can get a kit and fittings to install it at most box stores for less than $100.00.
In my area we have really nasty water from city water tower for in town and lots of wells with nasty rust/iron tasting water.
Everybody that ive done them for over the years has seen a definate improvement in water quality, and like o said you can still add a water soffener later to help fine tune the system if you need it.
Old 02-07-2014, 10:04 AM   #27
Rewards Points: 175
What unit did you have installed exactly?
Old 02-07-2014, 10:11 AM   #28
plummen's Avatar
Ive installed many differant brands of filters/housings over the years.
I usually use the ones that menards sells with the big blue housing , bigger the housing bigger the dilter surface area.
Old 02-07-2014, 10:17 AM   #29
Rewards Points: 175
Any chance you could link me? How often do you replace the filters?
Old 02-07-2014, 10:43 AM   #30
plummen's Avatar
It depends on how bad your water is as to how often you change it.
Ill look and see if I can find a picture for you.
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Water softener installation word2yamutha Plumbing 7 09-28-2013 12:27 PM
getting metals out of well water without a water softener? mlc28 Plumbing 6 11-19-2010 10:28 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
