Water Softener, Replace, Or Replace Beads? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2014, 11:09 PM   #1
Rewards Points: 161
Question
water softener, replace, or replace beads?
I have an older 70's style water canister looking guy, with an external salt tank.
The water pressure is horrible throughout the house when it is in the loop, so I bypass it currently, but everything is just getting chalky and mineraly! I was thinking, would it be cheaper for me to replace the beads, or the entire unit with something new?
The key thing here is to keep the water pressure!
vivithemage is offline   Reply With Quote
Old 01-27-2014, 11:21 PM   #2
Rewards Points: 13,732
If it's that old I'd replace it.
Old 01-27-2014, 11:44 PM   #3
Rewards Points: 161
replace it just because its old, or because i'll probably never achieve decent water pressure even if I replace the resin/beads?
Old 01-28-2014, 09:42 AM   #4
Rewards Points: 3,130
Replace it because it's old, outdated, inefficient technology. I'm surprised it's lasted this long. If something fails, you might not be able to get parts.
To each his own, but I don't believe anything related to my family's health is a DIY job. Though I have a lot of experience with water treatment and purification systems (primarily military), I don't mess with the unit in my home.
Old 01-28-2014, 11:23 AM   #5
Rewards Points: 161
I have zero experience and have the same belief on anything health/code related, and i'd LOVE to switch to a one unit system, as this thing takes up space being separate.
Any advice on decent high flow systems? I have a buddy who has a culligan, and said his water flow is pretty bad after he had it installed.
Old 01-28-2014, 09:42 PM   #6
My current unit is a Culligan, about four years old. Not sure what you mean by a "high flow system." My house is a typical 2-bedroom, 2-bath home, and I noticed no difference in flow to anything after installing the softener.
Old 01-28-2014, 10:23 PM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,728
Another vote for replacement as well.
I don't want to further the throw it out mentality of this country (that doesn't need any help) but I think it is safe to say you got your mileage out of it.
Old 01-28-2014, 10:29 PM   #8
Rewards Points: 161
I have only lived here a few months, just looking at things to replace now. I say high flow, as in I can use 2-3 faucts at once and not have the pressure disappear!
Old 01-29-2014, 07:53 AM   #9
Well, how big is your house, and how old? Using three faucets at once would be all the ones my house has; I've never tried it as there are only two of us.
I would assume, if your house is relatively new, that the plumbing would have been appropriately designed to accommodate the fixtures you have. If it's older, possibly with galvanized piping, nothing but total replacement will fix a pressure problem.
Old 01-29-2014, 08:15 AM   #10
PoleCat's Avatar
Rewards Points: 1,646
You on municiple water or a well? What size pipe feeds your house? What is the pressure? There may be other issues at play beyond the softner.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
plummen (02-06-2014)
Old 01-29-2014, 09:11 AM   #11
Rewards Points: 161
Nothing fancy, 3br, 2ba. It does have copper piping luckily.
but a more common occurrence .. washer and shower at once kills pressure. Or faucet + shower kills it too.
municipal. I would agree that someone else is the problem, but water pressure is great when we bypass the current water softener. For fun I tried 2 faucets, dishwasher, washer, and shower and pressure was great all around.
Old 01-29-2014, 09:35 AM   #12
Rewards Points: 34
It's probably best to replace it. Keep in mind that you need to clean the salt tank periodically. A one unit softener makes the task difficult.
Dan
djlandkpl is online now   Reply With Quote
Old 01-29-2014, 10:13 AM   #13
Rewards Points: 161
Makes sense. Any brand recommendations?
Old 01-29-2014, 10:22 AM   #14
Rewards Points: 34
I have a Culligan mark 100. Been trouble free for 12 years. Only bad thing is parts are proprietary so you have to get them from Culligan. Some parts can be found on eBay. Fleck seems to be a popular brand and can be DIY installed.
Dan
Old 01-29-2014, 10:27 AM   #15
Rewards Points: 161
Are any of the salt free solutions any good?
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Water softener installation word2yamutha Plumbing 7 09-28-2013 12:27 PM
getting metals out of well water without a water softener? mlc28 Plumbing 6 11-19-2010 10:28 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
