Old 09-06-2011, 01:44 AM   #1
Water Softener questions
I'd like to bypass and turn off a water softener for an extended period of time. Got some folks moving into a house that don't like soft water.
Easy to engage the bypass valve and unplug the unit. Is there anything else I should to to prep it for non use?
wireley is offline   Reply With Quote
Old 09-06-2011, 11:31 AM   #2
Water Treatment
Might have it do a regen or clean before you put the unit into non use.
Other wise that is about it.
Akpsdvan is offline   Reply With Quote
Old 09-06-2011, 11:40 AM   #3
Do I need to do anything with the brine tank? Draining it would be a big pain in the rump given the location.
In a year or two when I turn it back on does it need to be sanitized with bleach or something?
Old 09-06-2011, 12:33 PM   #4
Water Treatment
A year or two? If you are renting out the house, I my self would tell them to deal with the softener for the fixtures in YOUR house.
Old 09-06-2011, 12:40 PM   #5
The fixtures were fine for the 40+ years before we put in the softener so a couple more years shouldn't make a difference.
I just want to be sure that I take the unit out of service properly and then start it back up properly. I'm thinking some type of chemical will be needed to sanitize the unit after sitting for a long period.
Musty water from water softener tranders Plumbing 47 01-20-2013 02:37 PM
Culligan water softener not working (pics) Perm Plumbing 46 09-14-2011 01:29 AM
getting metals out of well water without a water softener? mlc28 Plumbing 6 11-19-2010 11:28 PM
Water Softener Help slivers Plumbing 4 08-01-2010 07:36 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
