Water Softener Problems Culligan Mark 89 - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-10-2012, 04:30 PM   #31
ajb
Floater
I finally got the water softner to use salt and it appears to be somewhat soft but the water isnt very "slimey" after washing. I read somewhere that when adjusting the amount of salt during a recharge you also need to adjust the "Float" (In the salt storage tank). Thanks for the advice.
ajb is offline   Reply With Quote
Old 06-10-2012, 10:53 PM   #32
Water Treatment
Rewards Points: 900
True, if the float is lower than it should be for say 4 gallons of water to do the 12lbs of salt then while the front many say 12 lbs you are only getting 9lbs of salt.
I will look to find the culligan manual that has the salt float settings to find out distance from float to floor for the different salt settings.
Akpsdvan is offline   Reply With Quote
Old 04-01-2016, 06:25 PM   #33
Rewards Points: 2
Re: Water Softener Problems Culligan Mark 89
Originally Posted by Akpsdvan View Post
There is a link, drop a line and it can be sent.
The kit that is for sale will work on the Mark 100, it is a full kit with many parts.
Know it has been awhile but looking for same part. If you still have access to one I would appreciate the source.
scristaldi is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water softener suggestions SixStrRzr Plumbing 8 02-04-2010 04:05 PM
Help with Water Softener TTran Plumbing 5 05-27-2009 06:08 PM
Water Softener "LOWERS PRESSURE" HELP! BobnSofi Plumbing 3 03-23-2009 02:24 PM
Water softener entry point? tigerbalm2424 Plumbing 4 09-06-2007 03:50 PM
