Water Softener Problems Culligan Mark 89 - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2011, 01:12 PM   #16
Water Treatment
Rewards Points: 816
Originally Posted by dhp102 View Post
My Mark 89 sprung a leak and I was told I need a seal kit at $115. It was mentioned that there is a cheap one available. How would I go about getting one?
If you are in the US then the one that has one should be able, if Canada then that one will not send to Canada..
hidorsey@customcpu.com as new people can not pm ...
Akpsdvan is offline   Reply With Quote
The Following User Says Thank You to Akpsdvan For This Useful Post:
dhp102 (01-21-2011)
Old 01-29-2011, 03:24 PM   #17
Hello.
I have a Culligan Medalist softener that was manufactured in 2001. I bought it used (private sale) and just had it installed by Culligan. It has a small stream of water continually coming out the drain hose. It sounds as if I might need a seal pack? Any ideas on where to get one and how to install? Thanks.
bhnascar is offline   Reply With Quote
Old 01-29-2011, 03:36 PM   #18
Water Treatment
Rewards Points: 816
Originally Posted by bhnascar View Post
Hello.
If the unit is in service and there is water going to the drain then yes the main piston and seals most likely are the reason for the season..
There is a site that has one for sale at a very good price..
Drop an email, it is in above post..
Old 01-29-2011, 03:42 PM   #19
Thank you for the quick reply.
Yes, would greatly appreciate a link to this seal kit. This seem to be a common issue with Culligan units, but I cannot find much information on getting a kit and install instructions. I am fairly handy and wouldn't mind giving this a shot. Thank you!
Old 01-29-2011, 03:46 PM   #20
Water Treatment
Rewards Points: 816
Not a problem, I have a few for my customers that have culligan units, but they are more than what this one seller has for sale.
Every system out there has challenges much like what you have going on with your culligan unit.
Water going to the drain is a sign of seals not right or a piston with some nicks that has to be replaced.
Autorol valves have the flappers that can do the same thing and they have to be replaced when they are leaking.
This is like any car or truck engine that has rings go bad..
Old 01-30-2011, 03:59 PM   #21
Seal Kit
I have a Culligan Mark 100 with the same symptoms and wonder if someone can direct me to a source for a seal kit for it.
rbrucel is offline   Reply With Quote
Old 01-30-2011, 04:18 PM   #22
Water Treatment
Rewards Points: 816
There is a link, drop a line and it can be sent.
The kit that is for sale will work on the Mark 100, it is a full kit with many parts.
Old 01-30-2011, 04:27 PM   #23
mark 100 seal
Thanks for the quick reply, but I don't know how to contact you. My email is bruceark@gmail.com
Old 07-30-2011, 09:07 PM   #24
Akpsdvan,
I have a constant water run into the drain line on a mark 100, I am interested in the piston seal kit. unable to pm at this time(either I am to new and its not turned on or I just cant find the pm button) I can be reached at roycoates63@gmail.com
roy coates is offline   Reply With Quote
Old 10-11-2011, 09:58 AM   #25
Culligan Mark 89
I also have a Culligan Mark 89 and looking for a rebuild kit and or where i may purchase the o-rings and the white seals. My email is fredmeyerparts@yahoo.com any help would be greatly appreciated.
Thanks In Advance,
Cliff
CR42300 is offline   Reply With Quote
Old 04-27-2012, 08:31 PM   #26
ajb
Mark 89 Recharge????
Hi All,
I as well have a Culligan Mark 89. My problem is that I was continusly leaking from the drain line. I changed all the o rings and that resolved the leaking. My new issue is that now when I manually regenerate or let it go on schedule the water doesnt seem to be soft at all. I have upped the salt to 29 lbs for the regen and still no difference. Any help would be appreciated.
ajb is offline   Reply With Quote
Old 04-28-2012, 11:15 AM   #27
Water Treatment
Rewards Points: 816
Is the salt getting used?
If salt is getting used then there is either a challenge still in the valve that is letting un treated water past the system and into the house or the resin bed is bad.
Old 04-28-2012, 02:23 PM   #28
ajb
I do notice the salt diminishing each time I refresh. How do I go about checking the valve. I think I stated before that I am familiar with the unit as I have already replaced all the O rings. Thanks again.
Old 04-28-2012, 02:24 PM   #29
ajb
correction on the 1st post. the max salt I can use during a regen is 20 not 29. I hit the wrong key. sorry
Old 04-29-2012, 12:15 PM   #30
Water Treatment
Rewards Points: 816
If you are using salt when you start a manual regeneration there is no problem with the injector or brine piston.
Make sure that the bypass piston red and blue ends has the blue end all the way in.
Make sure that there is not another valve that should be closed ... open.
Make sure that the water has only one way to go , and that is through the system.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water softener suggestions SixStrRzr Plumbing 8 02-04-2010 05:05 PM
Help with Water Softener TTran Plumbing 5 05-27-2009 07:08 PM
Water Softener "LOWERS PRESSURE" HELP! BobnSofi Plumbing 3 03-23-2009 03:24 PM
Water softener entry point? tigerbalm2424 Plumbing 4 09-06-2007 04:50 PM
