-   -   Water Softener Problems Culligan Mark 89 (http://www.diychatroom.com/f7/water-softener-problems-culligan-mark-89-a-65252/)
Thespr 02-24-2010 02:29 PM
Hello,
I have a Mark 89 Culligan Watersoftener system and it does not appear to be working anymore.
From what I can tell, there is no flow out the drain line during any part of the regeneration sequence.
I manually moved the timer through the sequences and where I expect a backwash, there is none.
The brine tank is full of water and there are cycles were I can see a low flow of water into the tank and then a higher pressure flow of water.
I found this by pulling the brine line and moving the float around to engage or disengage.
Does anyone know which stage of the process the low flow is? Which stage has the higher pressure. I have lost track of the switch position for the various stages now as well.
Does the drain elbow pull out or screw out of the assembly?
Will cleaning inside help this? Is there a filter or screen that could be plugged?
Or, could it be a more significant problem such as a motor or pump?
I have the manual, but it doesnt really tell me how to do maintenance or take things apart.
Gary Slusser 02-24-2010 03:05 PM
It sounds like a blocked or kinked closed drain line, maybe it's frozen or in a puddle of ice or... the DLFC (drain line flow control) button/washer is blocked. The DLFC is inside the fitting that the drain line attaches to on the back of the control valve. Most of those fittings are screwed in but some newer designs have a plastic U shaped clip pin you pull out.
arcticbouncer 02-27-2010 05:02 PM
OK the drain elbow is removed by pulling up on the horse shoe clip near where the drain line connects to the head. pull this out and look inside there is a flow restrictor made of rubber pull this out and check it ( small hole about 3/16" dia. ) . Now that is done but I dont think that is the problem .. pull out the two screws from the face plate and remove it look under the motor unit at the piston push rod.. see anything broken yet maybe a bell crank no .. ok put the unit in bypass and get ready to take some stuff apart ( the fun stuff ) pull the motor off and go back to the lower piston assm. move the piston in and out this is usually where the problem is most likley a broken seal pack assm. Have fun you will have to remove the upper cam in order to get the motor off and dont forget to UNPLUG THE UNIT FIRST !!! Let us know what turns up .
Thespr 03-07-2010 05:36 PM
Mark 89 Water softener
Gentlemen,
Thank you for your prompt responses to my inquiry.
I had an opportunity to get at the repair earlier this weekend and can report that the unit now operates correctly.
The issue was a clogged or significanly restricted stopper in the drain outlet. I pulled the assembly apart, removed and cleaned the stopper, reattached, and away it went. All cycles working well.
I suspect that part of the problem is that the drain line, due to the location and set up in the basement, must drain vertically. This allows some water to sit in the assembly after use, allowing the stopper to clog more easily, than if all the water drained out. This type of repair my have to be done a few more times, but at least I have a better idea how to do it.
Thank you once again.
Thespr
Hardchargers 01-15-2011 11:40 AM
Originally Posted by Thespr (Post 405315)
Hello,
Like this softener, mine is also not working properly. Unlike this one, mine continually flows out the drain line(non-stop).
Any idea where to look and what to do????
TIA
Akpsdvan 01-15-2011 12:13 PM
TIA
Main seal cage assembly and piston. one of the seal is cracked or pulled out of place letting water to the drain.
Depending on skill level it could a couple hour job or half the day..
Your main piston might be in good shape and most of the cage assembly with just one seal not right or you might need to replace all of them.
Age of the unit and iron and hardness level?
Hardchargers 01-15-2011 12:21 PM
Have no idea of specifics, but tannins in water(not much iron), been told the hardness here(rural) is comparable to the domestic water in the nearest city.
Unit is at least 10yrs old
Akpsdvan 01-15-2011 12:55 PM
So the unit is 10..
How often is the unit going through regen?
Either way I would be looking at the main seal and piston assembly... water to the drain while the unit is in service means that there is a challenge with some thing with in that assembly..
Challenge equals fix
problem more times than not equal no fix...
At least in my book...
Hardchargers 01-15-2011 02:17 PM
Originally Posted by Akpsdvan (Post 570752)
So the unit is 10..
I havn't added salt in months because of this issue....wanted to solve it first. Under normal use it was regenerating every couple of days.
Can a kit be purchased from Culligan or does this have to be done by a service tech.?
Thx
Akpsdvan 01-15-2011 02:24 PM
Thx
Getting the kit from a dealer depends on your local dealer as some will and some will not.
There is a kit that is cheap... send a pm and I will send the link to it..
Hardchargers 01-15-2011 02:37 PM
I think I'm too new to PM you as I can't find a way to do this. Never had a problem on other forums though.
Akpsdvan 01-15-2011 02:44 PM
Might be that to new to get to send a pm,,,
Thank goodness that some of us are on other DIY sites and most use the same handle..
Hardchargers 01-17-2011 03:02 PM
Hey Dude,
Still can't PM. Why don't u PM me the link:thumbup:
Akpsdvan 01-17-2011 03:09 PM
Looks like I can not send a pm to you...
dhp102 01-21-2011 12:02 PM
inexpensive seal kit
My Mark 89 sprung a leak and I was told I need a seal kit at $115. It was mentioned that there is a cheap one available. How would I go about getting one?
