Water Softener Opinions - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-13-2012, 03:20 PM   #1
Greg
water softener opinions
we are moving to a new house and will be on well water. decided to have the well tested and the results were
hardness 5 gpg
iron .5 mg/l
ph 6.2
tds 62 mg/l
They recommended a water softer for a price of 2300.00
To me the numbers are borderline across the board. The well was dug / drilled last summer and has been used very little since.
thoughts?
scuts is offline   Reply With Quote
Old 03-13-2012, 04:01 PM   #2
Water Treatment
Rewards Points: 898
If the well can handle it, I would run the water out a hose at 4gpm for at least 48 hours with out turning it off and then testing the water again.
Akpsdvan is offline   Reply With Quote
Old 03-13-2012, 06:16 PM   #3
Agree with the recommendation to flush the well and then retest the hardness and iron.
If you have copper plumbing the pH needs to be treated--otherwise you will be replacing copper pipes with pin hole leaks in a few years. Flushing is unlikely to change the pH.
The hardness and TDS numbers don't make sense. 5 grains of hardness equals (5 x 17.1 ppm) a TDS of 86 for the hardness alone. Any other dissolved matter would further increase the TDS.
Bob999 is offline   Reply With Quote
Old 03-13-2012, 07:08 PM   #4
Rewards Points: 626
I live on a well a artisan well and I have hard water but I can't stand the salty slimy feel I got with a water softener. So I just don't soften my water and the side effects are Not a lot of suds don't lather up in the shower. Calcium deposits and the most noticed difference is great tasting water not slime feeling
Nailbags is offline   Reply With Quote
Old 03-13-2012, 09:48 PM   #5
If your softener produces salty water then it is not working or set up properly. That feeling with the softener is clean skin.
Andy CWS is offline   Reply With Quote
Old 03-13-2012, 10:28 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
This is my prefered method for dealing with most water issues on customers houses
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Ravenworks (03-18-2012)
Old 03-17-2012, 08:19 PM   #7
Greg
details on that filter? We also just tested positive for bacteria. Its a 300ft rock well. I was told to pour 3 gallons of clorox down the vent hole and run the hose until I smelled bleach. I ran ot for 7 mins and never smelled it. Should I add more bleach?
Old 03-18-2012, 01:27 AM   #8
plummen's Avatar
Theres differant cartridges/filters for differant water issues.
Id have the water checked and find out what it is thats actually in there first
Old 03-18-2012, 09:18 AM   #9
Ravenworks's Avatar
That filter makes my water crystal clear and it taste great,I like the fact that there are not things floating around in my water after the ice melts.
Ravenworks is offline   Reply With Quote
Old 03-18-2012, 11:36 AM   #10
Rewards Points: 626
I have lived in the Intermountain west were Hard water is HARD WATER! no were else in the USA has harder water then Utah, Idaho. and every water soften I have used tastes slimy salty and is nasty. I love regular water non salty junk.
Musty water from water softener tranders Plumbing 49 05-03-2014 01:17 PM
Need Help Buying a Sediment and Water Softener System. vpr80 Plumbing 10 02-23-2012 10:26 AM
Water Softeners rickglarson Plumbing 1 01-09-2012 04:10 PM
Water softener or water filter Ext290 Plumbing 7 12-26-2011 10:48 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
