-   -   water softener opinions (http://www.diychatroom.com/f7/water-softener-opinions-136933/)
scuts 03-13-2012 03:20 PM
we are moving to a new house and will be on well water. decided to have the well tested and the results were
hardness 5 gpg
iron .5 mg/l
ph 6.2
tds 62 mg/l
They recommended a water softer for a price of 2300.00
To me the numbers are borderline across the board. The well was dug / drilled last summer and has been used very little since.
thoughts?
Akpsdvan 03-13-2012 04:01 PM
If the well can handle it, I would run the water out a hose at 4gpm for at least 48 hours with out turning it off and then testing the water again.
Bob999 03-13-2012 06:16 PM
Agree with the recommendation to flush the well and then retest the hardness and iron.
If you have copper plumbing the pH needs to be treated--otherwise you will be replacing copper pipes with pin hole leaks in a few years. Flushing is unlikely to change the pH.
The hardness and TDS numbers don't make sense. 5 grains of hardness equals (5 x 17.1 ppm) a TDS of 86 for the hardness alone. Any other dissolved matter would further increase the TDS.
Nailbags 03-13-2012 07:08 PM
I live on a well a artisan well and I have hard water but I can't stand the salty slimy feel I got with a water softener. So I just don't soften my water and the side effects are Not a lot of suds don't lather up in the shower. Calcium deposits and the most noticed difference is great tasting water not slime feeling
Andy CWS 03-13-2012 09:48 PM
If your softener produces salty water then it is not working or set up properly. That feeling with the softener is clean skin.
plummen 03-13-2012 10:28 PM
1 Attachment(s)
This is my prefered method for dealing with most water issues on customers houses :)
scuts 03-17-2012 08:19 PM
details on that filter? We also just tested positive for bacteria. Its a 300ft rock well. I was told to pour 3 gallons of clorox down the vent hole and run the hose until I smelled bleach. I ran ot for 7 mins and never smelled it. Should I add more bleach?
plummen 03-18-2012 01:27 AM
Theres differant cartridges/filters for differant water issues.
Id have the water checked and find out what it is thats actually in there first :)
Ravenworks 03-18-2012 09:18 AM
That filter makes my water crystal clear and it taste great,I like the fact that there are not things floating around in my water after the ice melts.
Nailbags 03-18-2012 11:36 AM
I have lived in the Intermountain west were Hard water is HARD WATER! no were else in the USA has harder water then Utah, Idaho. and every water soften I have used tastes slimy salty and is nasty. I love regular water non salty junk.
