Water Softener Off The Main Line? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-03-2009, 01:48 PM   #1
Water softener off the main line?
I'm not sure I'm looking at this right. We have *very* hard water - scaling on pool tiles, shower walls, etc... We don't have the designated pipes in our garage for water softeners, but I'm thinking I would rather have it outside off the main line so the pool's auto filler will use the soften tiles. I'd put a water filter in the kitchen for the faucet and the ice maker. Is it a problem to put one off the main water line?
scottyja is offline   Reply With Quote
Old 02-03-2009, 07:16 PM   #2
Safe, Most of the Time!!
brokenknee's Avatar
No it would not be a problem. Everything in the house would be soft.
I don't know about you, but even with a carbon water filter I do not like the taste of soft water. If you have an RO then it should be soft.
The other issue you have is the automatic pool filler; I don't know how much make up water that it adds at one time, but not sure the softener would be able to keep up with it. If it doesn't keep up all the water will be hard.
You could branch off before the before the softener and run lines to your pool and for drinking water.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Gray PCV for water supply line - is this OK? Jim S. Plumbing 13 08-09-2010 09:20 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Water main freezing intermittently rballard Plumbing 8 12-31-2008 02:05 AM
Moving water softener... epeterson777 Plumbing 1 09-07-2008 11:03 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
