Water Softener Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-30-2011, 08:41 AM   #1
water softener issue
I did a basement remodel last year. Took out the existing bathroom and made it into a mech room. Problem is now after moving the water softener to this room, I am not getting soft water. I filled it up with salt and it is still full(prob 3 months ago)? I called Kenmore and they said to clean this and that, then "recharge now", did that, still not softening the water. Any ideas what is happening or not happening with this? Thanks-Brad
BULLMN11 is offline   Reply With Quote
Old 04-30-2011, 08:52 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 154
Wrong forum, perhaps one of the Mods will move it soon to the Plumbing forum.
Old 04-30-2011, 09:25 AM   #3
An old Tradesmen
Rewards Points: 7,816
Moved to plumbing forum.
Old 04-30-2011, 09:53 AM   #4
Water Treatment
Rewards Points: 900
Double check that you have the in on the in and the out on the out.
Double check that the bypass is open and water it flowing through the unit.
The unit should have some thing in the read out that shows the water flow, if it is flashing while water is flowing then the meter is counting, if not then the meter is hung up with some thing and needs to be cleared out so that it can turn, no turn no counting of water flow.
Akpsdvan is offline   Reply With Quote
Old 04-30-2011, 11:09 AM   #5
I did the water test you are describing with a Kenmore rep. Water is being counted. Bypass is open.
First time home owner furnace/hot water issue rjohnson84 Plumbing 17 12-20-2010 10:40 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Water softener no longer softening water grandmajo Plumbing 3 01-19-2009 06:42 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Is this a viable solution for a water softener? imola ghost Plumbing 1 12-23-2008 10:51 PM
