Water Softener Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-28-2013, 08:52 AM   #1
Rewards Points: 160
Water softener installation
I just got my water tested and it scored a 10gpg. I went out and bought a kenmore 300 series water softener. I have a weird water setup in our house.
The water meter is located in our basement about level with the water softener. In the manual is says to locate the water softener as close as the main water line as possible. I would rather have the outside water spouts remain on hard water, but it would probably be expensive with the added addition of copper piping.
Would I have to relocate the water meter? If I can, can I legally do it on my own or does the water company have to move it? The closest drain is about 15ft away. Also is it ok to drain to the sump pump? Im guessing the salt would kill the grass and ruin the pump as well. If you guys could steer me in the right direction I would be grateful. Thanks
Also, just ignore the downspout on the main water line. Some how it passed inspection lol.
Water softener installation-20130928_083741.jpg   Water softener installation-20130928_084011.jpg
word2yamutha is offline   Reply With Quote
Old 09-28-2013, 09:33 AM   #2
Rewards Points: 240
what is the before meter, top or bottom ? doesn't matter. just 90deg in and out from after the meter .
Fix'n it is offline   Reply With Quote
Old 09-28-2013, 09:38 AM   #3
Rewards Points: 240
here is mine
Water softener installation-img_2169.jpg   Water softener installation-img_2168.jpg
Old 09-28-2013, 09:53 AM   #4
Rewards Points: 160
I guess I made it more complicated then I thought lol. So from the main water line to the "in" then "out" goes back to the main water line. Im assuming you don't use lead solder correct?
Nice job on your install. Have any suggestions for a drain that is 15ft away? I guess I could just run a long drain hose. Just going for a nice installation.
Old 09-28-2013, 10:02 AM   #5
I'm unsure what "So from the main water line to the 'in' then 'out' goes back to the main water line." could possibly mean.
Very confusing.
After your meter, but before the softener, solder in a "T" fitting. Off the "T" solder in a 1/4 turn full port valve, and plumb that line to your outdoor sillcocks.
RoyalAcresRod is offline   Reply With Quote
Old 09-28-2013, 10:50 AM   #6
Rewards Points: 160
Very confusing.
The "in" and "out" is referring to the bypass valve. Thats how there labeled on mine. If copper was cheaper I would probably install those lines for the ourdoor sillcocks. I dont really water much outside anyways. Its probably a good idea though to install a t-valve and put a cap on it just in case I change my mind though.
Old 09-28-2013, 12:01 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
Re-plumb the outside with PEX
Coastal South Carolina
Old 09-28-2013, 12:27 PM   #8
Rewards Points: 160
Would it be possible to tie the drain from the water softener into an existing drain such as a bathtub?
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
water smells Culligan water softener brianksca Plumbing 1 09-01-2012 07:29 PM
Water Softener Drainage Problem hodge23 Plumbing 3 09-26-2011 04:40 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
