Water Softener Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-08-2013, 07:12 PM   #1
Rewards Points: 41
Water softener install
Is a water softener replacement a reasonable DIY project for an amateur?
I normally stay away from major plumbing because there's too big an opportunity for major disaster. However, my neighbor just let me know that this morning he saw "water spraying out of the top of the water softener in a way that didn't look normal", and the thing hasn't been working lately anyway. It's so old I can't even get a manual for it.
Unfortunately a water heater replacement last month wiped out my cash reserves, so if I can install a $600 unit myself instead of paying the plumber lots more $$$ it would make a big difference.
From the looks of it it's just an inlet and outlet line, and a drain pipe and electrical. Everything is already there for the old unit and the feed lines are flexibe, so it should mostly just be two threaded joints, right? See the picture below of the existing unit.
Also, anyone have recommendations on makes/models? This is a fairly big house, but there are only two of us living here so our water needs are modest. However the water here in Pasadena is pretty hard; my cheapo meter reads ~350 TDS, and it shows on our dishes rapidly.
Many thanks!
IdahoEv is offline   Reply With Quote
Old 04-08-2013, 08:17 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 904
As i was reading- I was trying to figure out how your neighbor could see water spraying inside your house Then I saw the picture and realized the softener is outside and you life in a warm climate
You pretty well described the process of installing a new one . You might encounter a hiccup here or there though - nothing too tough.
Several members here have softeners(I don't) so I'll let them make recommend units.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
water softener install/manifold question climbhigh1119 Plumbing 10 03-07-2013 11:36 PM
Well water + water softener led to low water flow AmandaJayne Plumbing 2 02-19-2013 11:00 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
