-   -   Water softener entry point? (http://www.diychatroom.com/f7/water-softener-entry-point-11309/)
tigerbalm2424 09-06-2007 08:50 AM
My house is ten years old, basement not finished, never had a water softener. Beyond choosing a brand/type/model of softener, where do people typically attach to their water lines? Do I need to run new lines from the softener to the specific places I want soft water? :(
DIY4EVER 09-06-2007 09:13 AM
Typically you will want the water softener installed right into your water main somewhere convenient before the water heater. This way, all the water coming into your home through the main line will be "softened". Your cold water line branches off of your main line at some point and feeds all your fixtures. Your hot line comes off of your water heater and feeds all of your fixtures. So, by having the softener in your water main before the water heater will soften all your water at every fixture, no need to run any new lines to individual fixtures.....all the water at every fixture will be treated as soon as it comes into your home via the main line. Just make sure the location is convenient to get to since you will need to add salt or service the softener regularly. Also, if you plan any future renovations to the basement space, it will be easy to close in the area around the softener is you plan ahead and locate it in a good spot. :thumbsup:
tigerbalm2424 09-06-2007 09:30 AM
Thanks for the reply. Builders of the house were first timers I think(first noticed they cheaped on EVERYTHING!). Water main comes up out of floor in opposite corner of basement from the water heater. I understand thats not a problem but the problem lies in the fact that the main splits as soon as it comes into the basement, plus, the water main comes out of the concrete in what was blueprinted to be a bedroom.
"hey timmy, while you are cleaning out the clothes from your bedroom closet, can you please add salt to the softener!":laughing:
DIY4EVER 09-06-2007 01:54 PM
I am assuming that when the water main splits one line goes to the water heater and the other is the cold water line feeding the house?? You can cut the main just before the "split" and install the softener, then just run a new line from the softener back to tie into the cold line and then hook the line back up to feed the water heater. If you have copper pipes you make sure your soldering techniques are good. May not be a bad idea to get it prfessionaly installed....
concretemasonry 09-06-2007 03:50 PM
If you are not careful about the softener location, you could end up softening all the water from your hose bibs that you use for the lawn.
