Old 10-28-2009, 10:02 PM   #1
Default water softener drain line
I will be hooking up a water softener in my house this weekend.
It needs a drain line connected and over flow drain line. Problem is that my sump pit is about 45 to 50 feet away. Can i run a drain line this far if it is a flat run. The instructions call for 3/8 inch diameter, should i increase to 1/2 inch or 3/4 diameter?
moreira85 is offline   Reply With Quote
Old 10-29-2009, 01:45 PM   #2
Water quality'n pump guy
You must have bought a big box store brand softener. They are the only ones that call for less than a minimum 1/2" ID drain line (which is industry standard).
I would not run a 3/8" anywhere near that far, I would use 1/2" at least. Control valves that I sell I use 1/2" up 6-7' above the control valve and then sideways 20-30' and 40' if you bring the drain line back down.
If you get this wrong the softener wil not work right very long.
And use PE, not vinyl that will kink closed just from its weight.
Gary Slusser
22 years in water treatment and well pumps, 13 years on the 'net helping others to help themselves.
Gary Slusser is offline   Reply With Quote
Old 10-29-2009, 02:09 PM   #3
Can you not tie into some existing drain line in your house? That's what I did.
Old 10-29-2009, 02:12 PM   #4
Won't the salt encourage your sump pump to corrode?
Old 10-29-2009, 02:27 PM   #5
no, its a walk out basement so just a sump pit with no pump. the pit has a 5 inch drain hose that runs under the slab out to a neutral location.
Old 10-29-2009, 02:29 PM   #6
no the closest drain in the house in the basement is even a further run.
I am assuming that 1/2 inch PE tubing run 45 feet on a level run with one left hand turn would be the best bet.
Old 10-31-2009, 02:14 PM   #7
If u need some good water softeners...then i would recommend you here...http://www.isopurewater.com/ using there softener for a year now and never had a problem...
good luck!
AdamHart is offline   Reply With Quote
More On This Topic
The beer bong is one of the few objects that college students and other beer lovers consider absolutely essential. The beer bong, sometimes called "the funnel," allows for a fast jolt of foamless beer to shoot from the can straight down the hatch. Build... Read More »
The next thing we are going to do is turn off the gas supply to the stove. There usually is, this is like, I think, a 1/2" or 3/8" gas line, you might want to just replace this. This is a new one. So anyway, you would generally have a gas valve that... Read More »
OK, here we're going to talk about how to fill and drain a spa. Some people tend to think they have to be plumbed in or hard plumbed with a current plumbing system in your home. Not the case, you simply grab a garden hose, place the hose into the spa. In... Read More »
We are doing a kitchen remodel, and we’re installing the sink. We have replaced one of the supply lines, we have the sink in, and the supply line is connected to the outlet valves. Now we’re going to install a dishwasher drain. You put it on... Read More »
What are Tuba Bores?
What are Tuba Bores? by Expert Village
Hi, Kevin Smith, TubaLove here again, talking about the bore. That's b o r e of the tuba. I had just briefly mentioned bores when I was talking about the size of the tuba. What the bore is it's the inside diameter of the instrument. And it's usually... Read More »
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 09:09 PM
Very Low Hot Water Pressure. PAS1970 General Discussion 2 02-25-2009 05:01 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 01:41 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 10:36 PM
Water and Drain Line Location Material Tester Plumbing 1 11-27-2007 09:40 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
