Old 07-05-2012, 08:44 PM   #1
Water softener drain fitting
Where can I get a fitting from my sottner into my 1inch copper waste drain?
Fatro is offline   Reply With Quote
Old 07-06-2012, 12:02 AM   #2
Water Treatment
Not sure as to what softener you have , but you should be able to find fittings to make a change from the size of tubing that comes off the softener to the drain that you are working at using.
Akpsdvan is offline   Reply With Quote
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
New Drain and Overflow assembly not fitting properly to new tub - Help plz amodoko Plumbing 19 12-21-2011 03:28 AM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Very Low Hot Water Pressure. PAS1970 General Discussion 2 02-25-2009 04:01 PM
