Water Softener Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-07-2010, 03:55 AM   #1
Water softener drain
I'm installing a softener in the garage. House is on well with septic. I'm thinking of running the drain line into the house washer drain. To do this I would have to run the drain line overhead thru the ceiling to the house. My question, does a softener "push" the water out the drain, thus allowing the hose to run overhead, or must it be run downward of the outlet?
nicko is offline   Reply With Quote
Old 12-07-2010, 09:44 AM   #2
Rewards Points: 120
Not an expert, but mine anyway has pressure behind it when it drains. Before going too far though, I just wanted to mention that you may want to check with your local jurisdiction, as there has been a fair amount of controversy concerning the affect of water softeners on septic systems, and I believe that some municipalities have legislation regarding the right and wrong way to handle this.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
How do I drain my water heater? HVAC_NW Plumbing 10 11-10-2010 03:15 PM
Drain for Water Softener... Mr Ron Plumbing 9 10-04-2010 12:44 PM
Flooded Salt Tank in Kenmore H2O Softener whitedavidp Plumbing 2 01-07-2010 12:05 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
