Water Softener Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-15-2010, 11:17 AM   #1
water softener drain
What would be the best way to drain my water softener ? I have a septic system. I was thinking of building a french drain with pea-gravel into the ground. Thx
gccrafty is offline   Reply With Quote
Old 07-16-2010, 12:31 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
My water softeners have always been in my utility room with the washer & dryer since I built this house in 1977. It is on a standard septic system.
The softener regeneration discharge has always just been a long, smaller size black plastic flex hose just run over and stuck down into the washing machine drain standpipe going into the septic system.
Never had any trouble with any of it. Actually, I think that the softener disharge helps keep the washing machine drain cleaned out with the pressure.
A french drain may eventually plug up.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-16-2010, 08:23 AM   #3
Thanks Mike, I appreciate the answers on my drainage problem. Sounds like some good ideas! Jerry
Old 08-04-2010, 05:20 PM   #4
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
No sump pump in the crawlspace/basement to drain it too?
ryanh is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Flooded Salt Tank in Kenmore H2O Softener whitedavidp Plumbing 2 01-07-2010 12:05 PM
Water softener no longer softening water grandmajo Plumbing 3 01-19-2009 06:42 AM
Water flowing into emergency drain MetalChris Plumbing 7 08-09-2008 04:17 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
