Water Softener Control Head- How To Troubleshoot - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-19-2013, 12:29 PM   #1
Rewards Points: 1,062
water softener control head- how to troubleshoot
Softener hasnt produced soft water in a year. I suspect the head. In the past, I remember at night, about 3AM, hearing water rushing/hissing in the pipes, indicating softener was regenerating. havnt heard that for many months, so somethings wrong.
Its not that old. Where should I start to check it out to see if its shot entirely?
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 05-19-2013, 12:52 PM   #2
Water Treatment
Rewards Points: 850
First more information on the brand of system and if possible the head that is in use.
If you have not heard it doing a cycle it could be that the out let that it uses for power is dead.
It is possible that if it uses a transformer that the transformer is dead.
Start by finding out if there is power and if digital is the digital lit up and showing any thing.
Akpsdvan is offline   Reply With Quote
The Following User Says Thank You to Akpsdvan For This Useful Post:
noquacks (05-20-2013)
Old 05-20-2013, 07:11 AM   #3
Rewards Points: 3,130
Sounds silly, but have you checked to see if the softener is plugged in? Mine uses a small transformer like you might see for a cordless phone. Somehow, when refilling the salt tank, I accidently knocked the transformer out of the outlet, probably when removing the tank lid. Didn't notice anything was wrong until the dishes started coming out of the dishwasher with spots on them.
The Following User Says Thank You to md2lgyk For This Useful Post:
noquacks (05-22-2013)
Old 05-22-2013, 02:38 PM   #4
Yup, its plugged in. Warm to the touch too. gonna check it out right now....
Old 05-22-2013, 02:39 PM   #5
OK, power to outlet for sure is not dead (transformer is warm to touch, as I mentioned above). Yup, digital display shows up. displays the time of day.
Old 05-22-2013, 03:09 PM   #6
heres where I bought it:
http://www.budgetwater.com/water_softener.htm
had trouble with it from the beginning. erratic water production- sometimes soft, then for a week, regular hard water. Sheesh.
Old 05-28-2013, 06:08 PM   #7
OK, ran it through the entire cycle, manually. Took about 2 hrs. Now, no soft water. Still keeps time. Could it be bad/depleted resin beads? So soon? Beads are supposed to last for many years......
Old 05-29-2013, 11:42 AM   #8
Water Treatment
Rewards Points: 850
Is it the one that goes off x number of days or the meter?
Meter one goes when x number of gallons has been used.
When it went through a cycle was salt used or did the salt go down?
Could be that the unit is not going off enough or no days are set or that the gallons is way to high or that there is a salt bridge and no salt is where the water is in the salt tank.
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Water Softener Questions :) Einzee Plumbing 6 08-13-2011 11:55 PM
Water Softener Resin Bed Clogging with Sediment? batman71 Plumbing 2 02-23-2011 11:38 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
