Water Softener Brine Tank Smell - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-29-2010, 08:15 AM   #1
Water softener brine tank smell
Greetings. I've just purchased a 16 year old home with its own well. The home was in forclosure for ~ 1 year, so I know little about it. It appears to have a standard water softener, with analog timing. Before turning it on, I cleaned out the brine tank with bleach, replaced the old salt, and it appears to be softening / functioning fine. However...
I've been in the house for ~ 1 month, and have noticed an odor (like sulfur / sewer) in the brine tank itself. The brine water looks a little greyish. However, the water in the rest of the house is fine...nice and "soft" and no odor.
In my previous home's water softener (on a city water supply), I've not encountered brine tank odor. Is this normal? Should I add bleach / hydrogen peroxide? How much?
Thanks in advance - Dale G
dcgroshek is offline   Reply With Quote
Old 06-29-2010, 09:26 AM   #2
Water quality'n pump guy
Mix a 1/2 cup of regular non scented bleach in a gallon or more of water and pour it into the water in the salt tank, not through the salt and leave it there until an odor returns. Remember that chlorine damages resins. So... next time use a 1/4 cup but since the water in the salt tank is not added to your water in the house, find something else to worry about or quit smelling the air in your salt tank. lol
You may want to have a Coliform bacteria test done on your water.
Gary Slusser
23 years in water treatment and well pumps, 13 years on the 'net helping others to help themselves.
Gary Slusser is offline   Reply With Quote
Old 06-29-2010, 01:25 PM   #3
Thanks! Water inspection prior to sale of home showed no coliform bacteria...however, no single test is perfect. Should the bleach treatment be performed no more than twice?
Old 06-30-2010, 01:09 AM   #4
Get the bacteria test done.
The more chlorine the faster it damages the resin. So only use it infrequently and onlt a couple capful after the initial two times.
Gary Slusser
water softner and brine tank ggallagher1 Plumbing 1 07-30-2009 11:28 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Stumped. Water heater woes. bigcaddy Plumbing 35 06-14-2009 05:12 PM
Help with Water Softener TTran Plumbing 5 05-27-2009 06:08 PM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 11:09 AM
