Old 10-20-2009, 10:03 AM   #1
Question Water softener backwash
My water softener back-washes into my sump pit, and then the sump pump flushes it out through the pipe to outside.
I was wondering if it would be advisable to route the backwash directly into the sump pipe as opposed to running it through the pit.
It seems to make sense to me, the sump pump wakes me up at 2AM when the system regenerates, and all the on-off cycles concern me with potential over use of the sump pump (not to mention the power usage) and premature failure.
Could I link the backwash directly into the out pipe? I presume I would need back flow valve
BimmerDOm is offline   Reply With Quote
Old 10-21-2009, 11:06 AM   #2
Water quality'n pump guy
Yes you could and you could install a check valve in the drain line of the softener and then deal with the softener not backwashing the resin well enough and then having to replace the resin. Ya see, all softenrs flow control the water going out the drain line, and any restrictions in the line reduces that flow more and that is bad for resin.
You should look at it this way, the one night a week that the sump pump wakes you is like a test of the sump pump system. Waking you means its working as designed, not waking you means you should test the system sometime to make sure it will work when needed, right, and you really don't want to do that, right? If it is waking you more frequently than once a week, you need to set your softener up on a more efficient setting, and it probably is too small so you might want to replace it and run the new drain line into the sewer or septic system where it belongs IMO. Choices choices...
Gary Slusser
22 years in water treatment and well pumps, 13 years on the 'net helping others to help themselves.
Gary Slusser is offline   Reply With Quote
Old 10-21-2009, 04:44 PM   #3
My softener backwashes every 4 days, that's how it was installed. Not sure how often I should get it to backwash.
My test at time of well drill was 318mg/L of hardness. I have a 42k grain softener, we are 2 adults and 2 small children in home.
Is 4 days too often?
Old 10-21-2009, 05:01 PM   #4
I would leave it like it is. A high quality pump should last a long time. Furthermore, it is normally code to have an air-gap between the domestic system, and any waste water system. And I assume that is what is being accomplished by this "backwash".
A number of things can be done to limit the noise
Anti-wingnut is offline   Reply With Quote
Old 10-21-2009, 05:17 PM   #5
Your softener 'regenerates' every four days, backwashing is part of the regeneration and many softener control valves actually have two backwashes per regeneration.
And it is not set up/programmed to give you 42K or it would be regenerating every 9 days on average but with terrible salt efficiency.
318/17.1=18.6, call it 19 gpg. You should have it set for 1947 gals or 37K IF you don't need a 24 hr reserve. If you do use 4560 grains or 240 gals per 24 hrs (1675 gals).
That gives you a regeneration every 7-8 days. That conserves water and salt.
You can learn all about that by Clicking Here
Gary Slusser
Old 10-22-2009, 08:55 AM   #6
Thanks Gary!
More On This Topic
The reason we have stopped is the filter has a lot of pressure on it and we need to backwash it and the reason it has pressure is because we're sucking these contaminants up and taking them to the filter so that they don't get back into the swimming pool... Read More »
So we've got our gloves back on, come over here we'll get our hot coat resin and our brush. Like I said, UV resin's in here; this never hardens as long as its not in a UV light. And thats the great thing when it comes to conservation of materials... Read More »
Laminating Surfboard Nose
Laminating Surfboard Nose by Expert Village
So we've got our lam resin and our brush, we'll just come over here and wet out that fiberglass, it's real generous and let it drip over. Keep everything inside that prep line, just like that. And what we'll do is come over here and just kind of get your... Read More »
A wet basement can wreak havoc on a home, resulting in cracks, destroyed possessions and contribute to the growth of unhealthy mold. Follow these quick techniques to safeguard your house against water damage. Read More »
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
Flood proofing Water Softener Supply Chemist1961 Plumbing 0 04-26-2009 05:23 PM
Water softener outlet.... theatretch85 Electrical 7 04-23-2009 01:29 AM
Water softener off the main line? scottyja Plumbing 1 02-03-2009 09:16 PM
Water softener no longer softening water grandmajo Plumbing 3 01-19-2009 08:42 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
