Water Softener Advice - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-11-2011, 12:50 AM   #1
Water softener advice
Hi
I've been doing some research and wonder if there are any experts
I see from a couple threads in plumbingzone that salt-free systems are scams
Can anyone comment on this site?
http://www.topwatersoftenerreviews.com/
Can anyone recommend a softner + drinking filter system?
Ricardo
Ricardok is offline   Reply With Quote
Old 12-11-2011, 09:34 AM   #2
H20 soft harmony. Great system. Easy to install. Holds 200 pounds of salt so you don't have to add salt as often
Service plumber is offline   Reply With Quote
Old 12-11-2011, 09:47 AM   #3
Originally Posted by Ricardok View Post
Hi
Ricardo
What is your water analysis? What water problems are you seeking to solve with a filter system? Are you on well or municipal water? How many people in the household? Do you have any large tubs or multi head showers or other high usage fixtures?
All of the above questions are relevant to selecting a softener and water filter system and without that information you, or any other poster, will not get informed opinions tailored to the specific situation.
Bob999 is offline   Reply With Quote
Old 12-11-2011, 10:06 AM   #4
For hard well water, water softeners are the ONLY cost effective way to treat the water. Charcoal filters, RO units cannot do this by themselves and can actually be ruined (clogged up) by running hard well water through them. Water filter scams abound such as using magnets to remove iron. All false - every one false. Or at best, they may remove a small portion of the dissolved impurities for a short period of time. Whoever can invent something to take the place of a water softener would be an instant multimillionaire.
Hates my roof is offline   Reply With Quote
Old 12-11-2011, 05:22 PM   #5
Hi,
I dont have actual test results for the water. I'm trying to solve problems with soap scum but most of all my wife has eczema and the hard water really makes her skin even worse. When we go to places where the water is soft the difference on the skin is significant
We have 2 full baths, one regular sized tub
Another concern is the effect of salt on plants. What happens to lawn, trees, etc? Dont i need another filter for that?
I would have to add another filter for drinking water
Ricardo
Old 12-11-2011, 05:30 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Id suggest a whole house filter where water service enters the house ,then see if the water improves before going water softener route.
plummen is offline   Reply With Quote
Old 12-11-2011, 05:42 PM   #7
When a softener is installed the water supply for outside hydrants and for irrigations systems should be BEFORE the softener--softened water should NOT be used for watering plants or other irrigations purposes.
But many people chose to have one outside faucet with softened water for car washing and similar purposes.
Old 12-11-2011, 06:24 PM   #8
Rewards Points: 582
I would recommend to have your water tested by certified company before anything...then see what is needed to improve water quality,,,,
Old 12-12-2011, 12:59 PM   #9
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
We're also considering a new system. What do you mean by "certified company"? In other words do you have any suggestions on finding a company that will give you honest advise rather than trying to sell you their product?
Old 12-12-2011, 04:24 PM   #10
Rewards Points: 338
for an irrigation system, yes, but if you use potassium instead of sodium in your softener, the outdoor faucets will be fine. potassium in the water is actually benefitial to plants, grass, trees, etc.
NitroNate is offline   Reply With Quote
Musty water from water softener tranders Plumbing 49 05-03-2014 02:17 PM
Water Softener, need some good advice. wla6518 Plumbing 11 07-07-2011 10:09 AM
getting metals out of well water without a water softener? mlc28 Plumbing 6 11-19-2010 11:28 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
