Water Softener - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-07-2011, 01:15 PM   #1
water softener
with no electricity attached the incoming water supply goes directly to the drain hose , the rotor is a little scuffed up, I was thinking either the rotor or a o-ring is bad, help needed
wickenfen is offline   Reply With Quote
Old 01-07-2011, 01:48 PM   #2
Water Treatment
Rewards Points: 902
Not sure what you have going on,
Is it that there is water going to the drain on your unit while it is in service?
What brand is the unit..
More information needed...
Akpsdvan is offline   Reply With Quote
Old 01-07-2011, 06:45 PM   #3
Sounds like the rotor is not in the service position--rather it is in some part of the regeneration cycle. That could be caused by a bad motor, bad switch, or defective control board. Alternatively it could, as you suggest, be a defective rotor or o-ring.
Try initiating a manual regeneration as see if the motor runs and the unit steps through each part of the regeneration to check to see if the motor and switch are working. If it steps through each part of the cycle then it is probably the rotor or o-ring.
Bob999 is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
What to put under water softener? wiz561 Plumbing 4 12-11-2010 08:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Went to city water - softener still needed? uncleslam General DIY Discussions 5 11-15-2009 04:08 PM
