Water Softener - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2013, 09:57 PM   #1
water softener
foamy and salty water
Richard 23 is offline   Reply With Quote
Old 03-16-2013, 12:21 AM   #2
Water Treatment
Rewards Points: 848
Brand?
City or Well water?
Do you have a manual for the system?
That should get things going, but there are a number or reasons but more information is needed.
Akpsdvan is offline   Reply With Quote
Old 03-16-2013, 03:06 AM   #3
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
Sounds like a well setup if the water is foamy. Fill up a glass with water and if the foam/bubbles go away in less than a few minutes then its just air in the water, if it doesnt you got a problem.
ryanh is offline   Reply With Quote
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 07:03 PM
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Water Softeners rickglarson Plumbing 1 01-09-2012 05:10 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
