Old 12-01-2012, 09:51 PM   #1
water softener
my water softener has a bad taste and smell what might be the problem?
stevemaj is offline   Reply With Quote
Old 12-01-2012, 10:20 PM   #2
Water Treatment
water softener
Way more information is going to be needed to even come close what could be going on or what might be happening with your system.
Akpsdvan is offline   Reply With Quote
Old 12-01-2012, 11:06 PM   #3
water softener
Is it both the hot and cold?
What's it smell like?
Are you sure it's working?
Have you had the water tested?
Is this a new house to you?
Old 12-01-2012, 11:12 PM   #4
water softener
boh hot and cold have a smell
taste bitter
its a new system in a new house both are about 5 months old
had the water tested where i test my pool water but only for clorine and salt both were ok at the time
Old 12-01-2012, 11:22 PM   #5
Water Treatment
water softener
Well or city water?
What kind of treatment is in place?
could the system be bypassed and the water tested to see if the smell and taste are there in the untreated water?
Bitter taste as in?
Smell as in?
Water Softeners rickglarson Plumbing 1 01-09-2012 05:10 PM
Water softener or water filter Ext290 Plumbing 7 12-26-2011 11:48 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
