Water Softener - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-04-2012, 03:47 PM   #1
Water softener
Mt softener is useing to much salt to fast. It appears it is putting too much water in the tub. It still softens the water but I can't keep up with the salt usage. I have cleaned out the tub and cleaned the screen. Steve
cs386546 is offline   Reply With Quote
Old 05-04-2012, 06:13 PM   #2
Is this a change?
What kind of softener?
What is the programming--particularly the brine fill time? What is the size of the Brine Line Flow Control? (the brine fill time and size of the BLFC control the amount of water added to make brine).
What is the size of the softener (cubic feet of resin)?
What is the hardness of your water?
Do you have iron and/or manganese in your water? If so, how much?
Bob999 is offline   Reply With Quote
Old 05-04-2012, 09:52 PM   #3
You can usually find an owners manual online if you google the model number. The troubleshooting section will send you in the right direction. If you run into a problem I'm sure someone here can help.
sanec1 is offline   Reply With Quote
Old 05-05-2012, 08:16 AM   #4
Water softener
Repling to the thread/The softener has been working perfectly for 5 years. Last time it did this the softftener people could not figure out what was wrong with it and replaced the valve on the bottle. It is a Alamo brand light commercial system model 2510 top mount control valve. The softener is 10 years old. Thanks Steve
Old 05-05-2012, 09:33 AM   #5
If the softener is regenerating with the same frequency the amount of water put in for brine fill (which controls the amount of salt used because 1 gallon of water dissolves 3 lbs of salt) must have increased. Check the programming to determine how many minutes of brine fill is programmed and then observe a manual regeneration with the line to the brine tank disconnected and put in a large bucket so you can measure the time of brine fill and the amount of water. If the actual time of fill exceeds the programming the problem is either with the timer motor or, if you have an electronic control, the control board. If the time is correct then the BLFC, which is a small washer with a hole in it to control water flow may be damaged or missing. allowing higher than intended flow.
Fleck makes a model 2510 valve and it MIGHT be what is on your softener. Check here:
http://www.pentairwatertreatment.com...Fleck+2510.htm
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Water Softeners rickglarson Plumbing 1 01-09-2012 04:10 PM
Water softener or water filter Ext290 Plumbing 7 12-26-2011 10:48 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
