Water Softener - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2012, 06:33 PM   #1
Water softener
The water softener seems to be effecting the water flow rate. With the system bypassed there is a little change in water flow in the sink in the bathroom when the toilet is flushed. With the system connected the water flow drops about 75% when the toilet is flushed. Any ideas?
bigalclerfl is offline   Reply With Quote
Old 03-29-2012, 07:03 PM   #2
MarginallyQualified
Rewards Points: 2,464
Is this a new problem?
Is there *also* a filter on the system?
How long since it was serviced?
Old 03-29-2012, 10:53 PM   #3
Rewards Points: 13,270
http://www.lvvwd.com/custserv/service_pressure_low.html
Old 03-29-2012, 11:06 PM   #4
Water Treatment
Rewards Points: 848
I would be looking at the pressure tank and the well pump.
If there is no change between the softener in service or out of service on the flow rate to parts of the house, then the softener is not the problem, it is either or both the pressure tank , well pump.
Akpsdvan is offline   Reply With Quote
The Following User Says Thank You to Akpsdvan For This Useful Post:
bigalclerfl (03-30-2012)
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Water Softeners rickglarson Plumbing 1 01-09-2012 05:10 PM
Water softener or water filter Ext290 Plumbing 7 12-26-2011 11:48 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
