Water Softener - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-30-2011, 04:29 PM   #1
water softener
just installed a water softener, but I don't see any water in the tank or see any movement with the system (it is plug in to the wall) when do i see the process or see it working?
Last edited by Mario Garcia; 05-30-2011 at 04:45 PM. Reason: just wonder when the system is going to star working
Mario Garcia is offline   Reply With Quote
Old 05-30-2011, 04:35 PM   #2
Water Treatment
Rewards Points: 902
What kind of softener is it? What brand?
There are some that put water in at the start of the Regen cycle and then there are others that put water into the brine tank at the end of the cycle.
Akpsdvan is offline   Reply With Quote
Old 05-30-2011, 04:49 PM   #3
What do i do? how long is going to take for the system to start working/
Old 05-30-2011, 04:52 PM   #4
GE 30000 grains from home depot
Old 05-30-2011, 05:03 PM   #5
Water Treatment
Rewards Points: 902
If the bypass is correct and you have it pushed for IN Service then there might be a flashing icon that shows that water is flowing.
There is also a button that you can push that will start a regen cycle, might have to push it for about 5 seconds for it to start, first point on the stop would be the brine tank fill..
In the book there are step by step points to start the unit up.
Old 05-30-2011, 05:10 PM   #6
thank you i'm going to do that
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
What to put under water softener? wiz561 Plumbing 4 12-11-2010 08:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Went to city water - softener still needed? uncleslam General DIY Discussions 5 11-15-2009 04:08 PM
