Water Smells Like Sulfur. Not Sure Water Softener Kicking On - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-10-2012, 11:36 PM   #1
Water smells like sulfur. Not sure water softener kicking on
How do I know if the softener is working? Should it be making noise?
nicknsuz is offline   Reply With Quote
Old 07-10-2012, 11:46 PM   #2
Water Treatment
Rewards Points: 816
There should be salt usage and you might hear water going to the drain when the system is in cleaning mode.
Akpsdvan is offline   Reply With Quote
Old 07-11-2012, 12:11 AM   #3
You might have a salt bridge.
VIPlumber is offline   Reply With Quote
Old 07-11-2012, 11:29 AM   #4
A water softener will not remove sulfer smell. Sulfer smell is typically a result of hydrogen sulfide in the water and can be removed by oxidation or, at low levels, by a carbon filter.
Sulfer smell from hot water only is typically caused by a chemical reaction with the anode in the hot water heater and can be dealt with by using a different type of anode.
Bob999 is offline   Reply With Quote
Old 07-13-2012, 09:25 AM   #5
Maybe I missed something. I don't see any question about sulfur. I don't see where he says his softener is not working, either.
If your water is hard, the softener is not working. If your cold is soft and your hot is hard, then your softener is working some of the time.
Andy CWS is offline   Reply With Quote
Old 07-13-2012, 09:33 AM   #6
Andy,
Read the title of the post.
Old 07-13-2012, 09:59 AM   #7
I had read the title but didn't see any question about sulfur. Nor did I see where he thinks his softener is not working. He just to know if it is working so I based my response on his post.
I guess I should have said that softeners only make noise when water is running through them (or they have a noisy clock) during service, brining or backwash. But one cannot conclude it is working simply because it is making a noise. There are a lot of noisy softeners out there that don't work.
I suppose I should have asked to provide more info, as well, since his post is a little shy on details or stated problems. So the best answer to his question if the softener is working is to test the hot and cold water.
On the other hand, he goes out and buys a sulfide system and finds out it is coming from the water heater-- oops. Just spent a lot of money on something that didn't work.
Low water Pressure with water softener garden Plumbing 8 07-31-2012 02:03 AM
Water Softener started regenerating when I was changing the water filter nicksergeant Plumbing 0 11-07-2010 07:17 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
Water heater/Water softener issues norrisboat Plumbing 2 01-24-2010 02:17 PM
