-   -   water smells Culligan water softener (http://www.diychatroom.com/f7/water-smells-culligan-water-softener-155518/)
brianksca 09-01-2012 06:27 PM
I noticed that the water is my house was smelling bad so I went to check the water softener. I discovered that the brine tank contained no salt and that there was about 6-8 inches of "dirty" water in the brine tank. I filled it with 80lbs of salt and then hit regen on the control panel. It made noise like it was doing something but the water still smells bad. I don't know anything about water softeners. Should the brine tank be full of water or does water just filter through the salt? Any Help would be appreciated.
Akpsdvan 09-01-2012 07:29 PM
Most likely the softener will need another regeneration to get fully clean. After the cleaning is finished make sure that there is about 3 hours before you start another.
The water is treated by the media that is under the control valve , the salt is what is used to recharge the media so that it can treat X number of gallons.
Water in the brine tank can look like what you are dealing with.
