Old 02-09-2009, 03:34 PM   #1
Water shutoff questions
Hello all, a few questions from a new homeowner:
I found the water shutoff to the house (outside) because I needed to fix a bathtub faucet. The repair went well, but:
1. I opened the faucet after the water was shutoff, and it seemed like the water, although trickling, kept on coming out. Also when I removed the faucet cartridge, there was a lot of water coming out of there too. Is that normal? I know that I turned off the valve as tight as I could.
2. When you turn the water back on, how far do you open the valve?
Thanks for any help,
RB Wallis
robwallis is offline   Reply With Quote
Old 02-09-2009, 04:22 PM   #2
bradnailer's Avatar
Sounds like the main shut off valve has some corrosion that is allowing some leakage. Not an uncommon problem. I'd open the valve all the way.
bradnailer is offline   Reply With Quote
Main water shutoff problem GoodoleBob Plumbing 18 06-16-2011 11:33 PM
hot water check valve? KE2KB Plumbing 7 01-30-2009 02:36 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
Master (water) shutoff valve rmdyjoe Plumbing 7 12-05-2008 09:55 AM
