Water Shut Off Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2013, 05:56 AM   #1
water shut off valve
are all 1/2 water shut off valve use the same size rubber grommet ? what size are they?
tomdel is offline   Reply With Quote
Old 01-24-2013, 07:51 AM   #2
Rewards Points: 582
I give up ben sr
Old 01-24-2013, 08:05 AM   #3
what that was no answer
Old 01-24-2013, 08:14 AM   #4
Rewards Points: 13,274
There's at least 3 or 4 differant styles of valves, hundreds of differant companys making them, valves do not use gromits, so I guess the ansewer is no.
If it's a gate or globe style valve it's very common for them not to shut completly off or leak due to there poor design and should be replaced with a ball valve.
Old 01-24-2013, 08:46 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Ayuh,.... Probably because all the Mind-readers are on vacation...
Old 01-24-2013, 10:17 AM   #6
Roofmaster
Rewards Points: 2,172
Grommet? What Grommet. Ain't got no Grommet! Grommet's on Tarpaulins, Got Picture?
Old 01-24-2013, 12:20 PM   #7
any good hardware store should be able to help you, you can get a pack of assorted sizes of rubber washers. if by grommet you mean the packing, the hardware store can help you there also.
Old 01-24-2013, 03:02 PM   #8
Rewards Points: 582
oh really it was a better answer than your question ben sr
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Can you solder within an inch of a closed shut off valve? amodoko Plumbing 17 08-16-2012 01:29 AM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 03:35 PM
How to Find and Shut Off the Main Water Valve PUTP Plumbing 16 01-08-2011 10:35 AM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
