Water Shut-Off....Knurled Nut - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-13-2010, 08:09 AM   #1
Rewards Points: 56
I have a water shutoff that is inside the house (just before it goes outside to a silcock) and there is a little knurled nut on the side of the valve. Am I correct in saying this knurled nut can be loosened (after the valve is shut off)to drain off excess water caught in the short piece of pipe going outside ?
Similar to this photo
wee-haggis is offline   Reply With Quote
Old 06-13-2010, 08:14 AM   #2
DIY staff
Rewards Points: 7,174
Yep--that's a drain cock. Just hope the installer put the valve in with the drain on the correct side!
Old 06-13-2010, 12:55 PM   #3
Rewards Points: 56
Thanks Mike
What do you mean ?
Old 06-13-2010, 01:58 PM   #4
DIY staff
I've seen them put in up-side down so the drain cock was on the pressure side--not the outlet side.
Old 06-13-2010, 04:14 PM   #5
Rewards Points: 56
Ahh,,,Ok.
I'll check
Thanks again
Old 06-13-2010, 04:29 PM   #6
iya
I saw such a nut under our sink (as I was trying to figure out how we can cram a dishwasher nearby, but that's another story).. how would you know, other than by trial and error, if it was attached correctly? Is there an arrow or symbol I can look for?
iya is offline   Reply With Quote
Old 06-13-2010, 05:06 PM   #7
Usually there's an arrow embossed into the main body of the valve to indicate the direction of flow!
The knurled petcock is installed on the house side of the valve, so that when the valve is shut off, water from the house can be allowed to drain back.
The Following User Says Thank You to Wildie For This Useful Post:
oh'mike (06-13-2010)
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 04:01 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
