Water Seeping From Well Head - Problem? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-23-2008, 07:08 PM   #1
Rewards Points: 262
Water seeping from well head - problem?
We have a well serving our house, and now, after weeks of almost continuous rain, there are thin jets of water coming through the bolt connections of the head cap and drips at other connection points. Clearly water within is under some pressure. Is this normal after so much rain? Does the pressure need to be relieved, and if so, should I simply try to loosen the bolts to alllow more water to stream out, or call a professional? I fear too pressure building building up and hurting our pipes! Any help would be most appreciated
tpagel is offline   Reply With Quote
Old 02-24-2008, 07:04 AM   #2
electrical contractor
Rewards Points: 150
Most artesian wells do not build enough pressure to damage the homes plumbing, just make sure to keep water out of the pressure switch, and control box if you have one. As for releiving the pressure, no need, switch off the pump and see if there is enough pressure to meet your demand inside the house, if so good for you, your cost to pump water just went to 0. When the pressure drops turn the pump back on. I have seen wells develop up to 60psi and stay that way for years with no detrimental effect on the homes piping.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
hot water recirculating/sediment confusing problem rcatty Plumbing 1 01-06-2008 03:51 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
recirculating hot water problem cliff Plumbing 3 08-20-2007 11:40 AM
water pressure problem rgmetro Plumbing 6 04-09-2007 03:57 PM
Water Delivery Problem amadis Appliances 6 12-20-2006 10:22 PM
